RBR20_user
Mar 08, 2020Aspirant
Orbi Blocking my IMAP server
I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone...
CrimpOn
Mar 08, 2020Guru - Experienced User
RBR20_user wrote:I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone if I turn off wifi and go cellular.
I have defaulted Orbi and power cycled cable modem to no avail.
I have also tried to add a service via security>block services>allow>and added imap port 143.
also added https 443.
Opening a port is for when there is a host connected to the Orbi that should be available to access from the internet. Orbi does not restrict connections to the internet. I just checked my Orbi. Not only can I "ping", but I can also connect to the IMAP server, which says that it is:
C:\Users\xxx ping imap.onebox.com
Pinging smtp.onebox.com [204.11.168.233] with 32 bytes of data
Reply from 204.11.168.233: bytes=32 time=13ms TTL=243
Reply from 204.11.168.233: bytes=32 time=12ms TTL=243
Ping statistics for 204.11.168.233:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 13ms, Average = 12ms
C:\Users\**bleep**>nslookup imap.onebox.com
Server: UnKnown
Address: fe80::a204:60ff:fe1c:239
Non-authoritative answer:
Address: 204.11.168.233
Aliases: imap.onebox.com
C:\Users\xxx telnet imap.onebox.com 143
* OK securemail.onebox.com MailSite IMAP4 Server 10.3.0.2 ready
What email application is being used, on what platform (Windows, Mac, Android?)
Does this Orbi have Disney Circle or Bitdefender Armor activated?
- RBR20_userMar 08, 2020Aspirant
hmmm
Well i cannot telnet to imap.onebox.com behind the Orbi, just times out, but I am able to directly to cable modem
The email clients are Outlood 2010 and Apple Mail Windows 10/7 and Apple OS 13.3.1
The logs from
C:\Users\xxxx>nslookup imap.onebox.com
Server: dns.google
Address: 8.8.8.8Non-authoritative answer:
Server: cdns01.comcast.net
Address: 75.75.75.75Non-authoritative answer:
Aliases: imap.onebox.comFROM BEHIND CABLE MODEM
C:\Users\xxxx>telnet imap.onebox.com 143
C:\Users\xxxx>ping imap.onebox.comPinging smtp.onebox.com [204.11.168.233] with 32 bytes of data
Reply from 204.11.168.233: bytes=32 time=36ms TTL=243
Reply from 204.11.168.233: bytes=32 time=38ms TTL=243
Reply from 204.11.168.233: bytes=32 time=38ms TTL=243Ping statistics for 204.11.168.233:
Minimum = 36ms, Maximum = 38ms, Average = 37msC:\Users\xxxx>nslookup imap.onebox.com
Aliases: imap.onebox.com- RBR20_userMar 08, 2020Aspirant
The logs dont report any blocking, is that expected?
- CrimpOnMar 08, 2020Guru - Experienced User
RBR20_user wrote:Well i cannot telnet to imap.onebox.com behind the Orbi, just times out, but I am able to directly to cable modem
I probably did not make clear that using telnet is an "Old Guy Trick" because telnet allows specifying the "port".
By default, telnet listens on port 23, but since the user can set software up any way they please, the telnet client will attempt to connect to whatever port the user enters. Is there an smtp server? telnet to port 25, and if it answers then yes. An ftp server? telnet to port 21.In this case, for an imap server, telnet to port 143 by adding 143 to the end of the command.
I no longer have Outlook 2010 (I had it before upgrading), and my Roadrunner email account used IMAP successfully on every Outlook since the early 2000's.
If you already tried to telnet to port 143 and it failed, then this is very strange.
I did not see whether Disney Circle or Bitdefender Armor are activated?
Definitely fails on port 143,with Orbi conectted however its also fails on port 25 using smtp.onebox.com. (Comcast blocking????)
But, if i bypass (direct to cable modem) the Orbi, i can retrieve email and send emails. But im using port 465 for SMTP which just gives a blank screeen when telneting.
C:\Users\XXXX>telnet smtp.onebox.com 25
Connecting To smtp.onebox.com...Could not open connection to the host, on port 25: Connect failedC:\Users\XXXX>telnet smtp.onebox.com 25
5: Connect failedC:\Users\XXXX>telnet smtp.onebox.com 465
I do not use the either Disney Circle or Bitdefender Armor, did the trial of Armor wheni first got router, but did not sign up.
