RBR20_user
Mar 08, 2020Aspirant
Orbi Blocking my IMAP server
I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone...
CrimpOn
Mar 08, 2020Guru - Experienced User
Alas, I fear my "Old Guy Tricks" are fading out. Almost all of the new email services, such as Google, use SSL connections and telnet cannot connect.
How about this for a test: Try to connect to any other well-known email services. I can reach these two:
telnet smtp.mail.com 25
telnet smtp.roadrunner.com 25
If you can reach either of these two, that (sort of) points toward OneBox.com as the problem.
If you cannot reach either of these two, I would be tempted to perform a "Factory Reset" and reconfigure and not activate Disney Circle or Bitdefender Armor until after getting email to work. https://www.youtube.com/watch?v=cMw4ePACgc4
RBR20_user
Mar 09, 2020Aspirant
I cannot get a reply from either server behind my Orbi, I’ll t try the defaulting procedure and give my results
Thanks
Thanks
