RBR20_user
Mar 08, 2020Aspirant
Orbi Blocking my IMAP server
I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone...
Mar 09, 2020Guru - Experienced User
RBR20_user wrote:I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone if I turn off wifi and go cellular.
I have defaulted Orbi and power cycled cable modem to no avail.
I have also tried to add a service via security>block services>allow>and added imap port 143.
also added https 443.
Firmware is current V2.3.5.26
any ideas????
- RBR20_userMar 09, 2020Aspirant
ARRIS Surfboard SB6183-RB 16x4
- FURRYe38Mar 09, 2020Guru - Experienced User
Ok, just checking to be sure there is no router there. You should be good up and thru the Orbi router though.
