jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
richc9990
Dec 27, 2018Guide
Many thanks. I'll give that a go now. Orbilogin was of course one of the sites I couldn't get to! Hope this works.
- joewermsFeb 11, 2019Initiate
Im having the same issue, how did you end up logging into Orbilogin ? It keeps blocking me! Cheers
- ekhalilFeb 11, 2019Master
joewerms , looks like you have double routers in your network and that's why you can't login to Orbi, and this is -probably- the reason of seeing some sites blocked.
Please open a Command Prompt on any computer attached to Orbi (the comupter you're trying to login to Orbi from) and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
If you see two private IP addresses listed in the first two hops then you have double NAT and you need to modify your setup. If you see only one private address and the second hop shows a public address, then you’re all good.
- joewermsFeb 11, 2019InitiateStand down I seem to have sorted it! How annoying though!!! 😡
- aknaussApr 04, 2019Initiate
Were you able to figure out how to log in to orbilogin.net? I can't get to log in.
- FURRYe38Apr 04, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What browser are you using?
Do you have a wire connected PC or laptop with a web browser navigating to orbilogin.com or 192.168.1.1?
