jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
Trudeau159
Jan 03, 2019Aspirant
Modem Combo Units:
Couple of options to try,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
My Setup (Cable 900Mb/50Mb)CM1100>XR450> > EX7700 (Wireless Extender)
Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111
