jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
Moviecane
May 03, 2019Aspirant
I have the most up to date firmware. Since I wrote the post, I also discovered that my Ring doorbell would not connect. I put it in AP mode like you suggested, and now everything works great! I'm not sure it is worth trying to play with the Orbi as a router if it is working so well as an AP. Thank you!
May 03, 2019Guru - Experienced User
AP mode on orbi is only needed if you have a main host router up stream from the RBR and it can't be either remove or bridged. Some cases the main host routers DMZ can be used for the Orbi to allow it to be used in router mode.
