jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
acemathias
Aug 01, 2019Aspirant
I'm having trouble getting to https://orbilogin.net/ too - it's being blocked because of this issue. Any hints on how to get to the settings so I can access the advanced settings and make this change?
- FURRYe38Aug 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?Are you trying to access the RBRs web page with a PC and web browser?
acemathias wrote:I'm having trouble getting to https://orbilogin.net/ too - it's being blocked because of this issue. Any hints on how to get to the settings so I can access the advanced settings and make this change?
- knmartinAug 21, 2019Initiate
I have read all the support and still can not figure out what to do... please keep answers simple as that was the whole reason i went with the orbi system.
it is an Orbi RBR40 with 3 satelites connected to att uverse - i cant even find this in the netgear drop down.
issue: Orbi is not connecting to websites - even the the orbilogin.net website is being blocked and asking for a password
background: i connected the orbi to my ATT uverse modem that was installed the previous day. Internet was running perfectly with the att router that was provided. I simply unplugged the att router and then plugged in the orbi router to expand the broadcast.
what is the step by step approach to fixing this? and please dont say "Configure the modem for transparent bridge mode"
- i have no idea what this means...
- i have the orbi app on my phone and thats about it. i cant seem to connect to the orbi on my computer, because of this issue.
- i have read about turn of double IP settings, or turn off this or that - but can not seem to find a simple step by step approach to fixing this problem that i was assured was an out of box solution for a simple person like me.
Please help.
- FURRYe38Aug 21, 2019Guru - Experienced User
Your ISP modem would already have a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
knmartin wrote:I have read all the support and still can not figure out what to do... please keep answers simple as that was the whole reason i went with the orbi system.
Please help.
- ekhalilAug 22, 2019Master
knmartin wrote:..............
knmartin Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
and paste the results here please.
- lerijOct 28, 2019Aspirant
Please help.
Please help.
I need this help
- TornadJan 24, 2020AspirantI cannot log onto Orbilogin.net (or dot com) on Mac as it keeps saying not secure. Downloaded app on phone, but seems not much can be done from there. Any ideas?
- FURRYe38Jan 25, 2020Guru - Experienced User
Use Safari, FireFox or Opera for Mac and log in to Orbilogin.com or 192.168.1.1. Accept the warning that the site is not secure. You'll be fine, it's just the browser warning you that the site is not using HTTPS vs HTTP.
