jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
MaryBirk
Sep 24, 2019Aspirant
I cannot log on to the OrbiNet site because my Orbi is blocking it. How do i work around this in order to access the page to allow HTTPS sites? Thank you!
Sep 25, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
MaryBirk wrote:I cannot log on to the OrbiNet site because my Orbi is blocking it. How do i work around this in order to access the page to allow HTTPS sites? Thank you!
