jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
talktochad
Feb 23, 2020Initiate
I've read the solutions listed here, but unfortunately I can't even login to the Orbi site, as it's restricting it as well. I type in UN/PW and it says the site is not secure. This is both on wifi and through ethernet/direct connect. WTF?
- schumakuFeb 23, 2020Guru - Experienced User
talktochad wrote:... I can't even login to the Orbi site, as it's restricting it as well. I type in UN/PW and it says the site is not secure.
Accept that the browser says it's not secure while using your home Ethernet/wired or the Orbi served WiFi.
Ask the browser maker WTF they consider a connection on a private network insecure and why they have no option to change it...
Netgear had a nice solution for using even https, and it nicely showed up green and secure. Some over-smart security "specialists" out there complained, so Netgear had to remove the perfectly working certificate. So we are back to plain http or https with a self-signed certificate.You are nagging at the wrong end of the chain.
- FURRYe38Feb 24, 2020Guru - Experienced User
Did you update FW to v2.5.1.8?
talktochad wrote:I've read the solutions listed here, but unfortunately I can't even login to the Orbi site, as it's restricting it as well. I type in UN/PW and it says the site is not secure. This is both on wifi and through ethernet/direct connect. WTF?
