jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
jflorez
Apr 05, 2020Initiate
Thank you. I had the same issue after switching from Comcast to fiber optic. I could not access some websites and certain apps such as Netflix (I could access it but I couldn’t stream). When i logged into the fiber optic’s wifi i was able to access those pages. But when i logged into Orbi, I couldn’t. After digging around I found this post and it solved it. Just add the https protocol so Orbi does not block it when the website does not specifically specify it in its URL. Thanks
- FURRYe38Apr 05, 2020Guru - Experienced User
Thanks for letting us know.
Enjoy.
