jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
MossyBoots
May 01, 2020Aspirant
After a fruitless 50minute phone call with NetGear (40min hold time), I was simply told to call Verizon.
I think my Verizon G1100 router is competing with my Orbi RBK50v2.
Is there any way to designate proper roles to each and move on?
This seems like such a rampant issue but I've yet to find a clear solution via multiple forum readings.
MossyBoots
Another point of inquiry:
Can't I simply remove my Verizon G1100 router and just go straight into my Verizon BIGBOX that's wired up to the brick walls of my basement?
- FURRYe38Jun 18, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
MossyBoots wrote:Another point of inquiry:
