jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
azdbo608
Dec 02, 2020Aspirant
How do you perform this when Orbi is blocking access to the the login site? I switched networks, but then of course, I can't login into the router when I am not on the Orbi network. This issue is infuriating!!
- FURRYe38Dec 02, 2020Guru - Experienced User
You need to be on the same network as Orbi.
Do you have two routers?
azdbo608 wrote:How do you perform this when Orbi is blocking access to the the login site? I switched networks, but then of course, I can't login into the router when I am not on the Orbi network. This issue is infuriating!!
