jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
Blanca_O
Dec 19, 2018NETGEAR Employee Retired
Hi jeffbr26
Thanks for sharing these tips on what is working for you.
Blanca
Community Team
bdiges
Feb 06, 2021Aspirant
I want to block youtube on the devices my kid uses. but not on the device I use. can we do that with orbi mesh network?
- schumakuFeb 06, 2021Guru - Experienced User
bdiges wrote:
I want to block youtube on the devices my kid uses. but not on the device I use. can we do that with orbi mesh network?Not with the default Orbi on-board keyword blocker - which can work with clear text http only anyway - I'm afraid.
The only way to achieve this is using some App on the end-point, like the Smart Parental Controls which comes in two flavors (Circle or Netgear Smart Parental Controls SPC) depending on your product. More and more devices will be added or migrated from Circle to SPC with coming-up firmware updates.
