jeffbr26
Dec 15, 2018Follower
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Cli...
Retired_Member
Jun 04, 2021I followed the procedure but the default port number for all websites was 443. That doesn't seem right. Plus, is this method bypassing security protocol and just allowing all websites through, regardless of their certificates, expired or not?
jeffbr26 wrote:ORBI is blocking HTTPS websites that are not explicitly defined in URL.
Click on Advanced Tab
Click on Security >> Block Services
Click Add
Click on Service Type DropDown and Select HTTPS
Click Add to save
Your all set. Close out admin and then retry ORBI admin console as just orbilogin.net and waalaa.Add Https as unblocked service
- Retired_MemberJun 04, 2021
That's strange how my Orbi RBR20 router did not produce the following error when trying to login by entering 192.168.1.1 into the browser and logged me in just fine for the longest time and then out of the blue I am no longer able to do this without changing a setting on my router to allow all https sites through. This seems very odd and incorrect. I sure hope this information is coming from an experienced networking and security professional at Netgear. You can't blame me for questioning it. While I'm inside the setting to block or allow services shouldn't I also add "DNS?" for all websites? Where can I find clear instructions that explain the use of these different settings?
Your connection is not private
Attackers might be trying to steal your information from 192.168.1.1
