Rosieag
Jun 02, 2020Follower
ORBI blocking websites when armour is turned off
I have an Orbi mesh network, it has recently been re set up due to some internet issues. The orbi network blocks wbsites even though the Armour security has been switched off. Has anybody got any ide...
bj10au
Jun 05, 2020Aspirant
I have exactly the same problem. I cannot access a website (www.digitalcamerawarehouse.com.au), which I have accessed many times in the past when connected through my Orbi router. I have turned Netgear Armor off using the Orbi iOS app, but that did not help.
I am able to access this website when I connect through my iPhone hotspot, so it is clearly a problem with the Netgear Orbi router blocking the website. The website is not listed as a blocked site in Armor.
The suggested solution is to reset the Orbi system and not turn Armor on, but this is not a satisfactory solution in my view, as I purchased a paid subscription to Armor for the protection it claims to provide.
My Orbi System is an RBR50 router, with two RBS50 satelites connected. Firmware is the latest version V 2.5.1.16.
Jun 06, 2020Guru - Experienced User
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
bj10au wrote:I have exactly the same problem. I cannot access a website (www.digitalcamerawarehouse.com.au), which I have accessed many times in the past when connected through my Orbi router. I have turned Netgear Armor off using the Orbi iOS app, but that did not help.
