pjm70
Jun 26, 2018Tutor
Orbi blocking websites when i connected to Altice 1 modem
I recently connceted my Orbi to the Optium Altice 1 Modem and after that i am restricted to websites. I have certain functions such as email and can access certain apps on my phone. Please help?
Jun 26, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem? Built in router here by chance?
pjm70
Jun 26, 2018Tutor
not sure the model number but it has built in modem and router...even when I plugged it back into the Verizon internet Orbi had the same issue which it never had before.
- FURRYe38Jun 26, 2018Guru - Experienced User
Modem Combo Units:
Couple of options to try,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.- pjm70Jun 26, 2018Tutor
thank i will try those.
