Gwgfree
Jan 27, 2018Initiate
Orbi Blocking Websites
After returning home and having the orbi offline (4 week) we turned everything back on and are having this issue: -some websites, including the Netgear website, are being blocked. Typical error messa...
JerseyJack
Dec 27, 2018Initiate
Hey folks, I was going down that path that someone recommended regarding how to configure my Orbi as a wireless access point (see here: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point) and when I logged into my Orbi using my iPhone (which was using the Orbi for wifi), I got a message that said (paraphrasing) "the Orbi has reconfigured its router address to avoid conflicts with your cable modem". Once it did that, I tried connecting from a pc to one of the web sites that was asking for my credentials, and I got right through with no prompt! Guessing the latest firmware helps fix this? I'm running FW version 2.2.1.210. Hope this helps!
Dec 27, 2018Guru - Experienced User
This would probably be due to your ISP modem already having a router built in and not FW related.
What is the Mfr and model# of the ISP modem your Orbi is connected too?
- JerseyJackDec 27, 2018Initiate
Actiontec MI424WR
- FURRYe38Dec 27, 2018Guru - Experienced User
Yep, router built in:
https://www.actiontec.com/products/wifi-routers-gateways/fiber/bhr-rev-i/
Reason way AP mode works on the Orbi. Your using the Actiontec as your router instead of the Orbi.
JerseyJack wrote:
Actiontec MI424WR
