Gwgfree
Jan 27, 2018Initiate
Orbi Blocking Websites
After returning home and having the orbi offline (4 week) we turned everything back on and are having this issue: -some websites, including the Netgear website, are being blocked. Typical error messa...
TonyArenas
Feb 06, 2019Initiate
So I called Netgear support and they told me what to do:
1) Have your device or computer logged into the network you have setup, then open a browser window. Type in www.orbilogin.net into the address bar and use "admin" fior the Username field, and type the password you created in the setup in the Password field.
2) You should see a screen popup with the newly created IP address and a button saying "Continue". Click on the button on the page and you should be redirected to a Netgear Dashboard for the Orbi.
3) Once you see the redirected dashboard screen, you should be able to open another browser tab or window and type in the web address you had a login screen for. You should now see the website instead of the login screen you saw before.
4) Enjoy the Orbi :)
