Mskinner712
Aug 02, 2019Initiate
Orbi blocking websites
Just purchased an orbi. It is blocking all websites including the Orbi admin site. Any help is appreciated. Tried to use support, says it is expired although date of expiration has not yet been reach...
Aug 02, 2019Guru - Experienced User
What browser are you using?
Can you connect to the RBR at 192.168.1.1?
Armor, Circle
Mskinner712
Your Product: AC2200 Orbi Micro Router(RBR20)
otherwise, I have no idea what you are asking.
- Retired_MemberAug 02, 2019
Mskinner712 wrote:..."otherwise, I have no idea what you are asking...".
This is becoming more common. Perhaps a breakdown in communication?
