happyandbob
Oct 04, 2018Aspirant
Orbi blocking work VPN for some computers
Hi, I'm my Orbi appears to be blocking remote networks for some computers but not others.
When I connect to my work VPN via windows integrated VPN client, on older Windows 7 machines, the VPN c...
Blanca_O
Oct 08, 2018NETGEAR Employee Retired
Hi happyandbob,
Please keep us posted.
Blanca
Community Team
ericvdb
Dec 27, 2018Tutor
I am having the same problem, trying to control social media for the kids...on an iphone turns out all they have to do is go to settings and turn on VPN or they get the speedify free vpn app and no traffic gets filtered. There must be a way to do this with at the router level, but toggling the social media category or specific app (snapchat, instagram) as 'not allowed' does not do any filtering.
EDIT: i have the Orbi RBK22, router plus one satellite kit
- ekhalilDec 27, 2018Master
Do you use Circle or OpenDNS for Parental control? Either way you can also block VPN for the kid's devices, please see below a snapshot from Circle:
happyandbob This can also be your issue with not working VPN for some devices. :)
- ericvdbDec 27, 2018Tutor
I should have mentioned, I use Circle, and I have the 'VPN and Proxy' set to not allowed, still does not work if VPN is switched on from iPhone.
- ekhalilDec 27, 2018MasterPlease have a look here: https://support.meetcircle.com/hc/en-us/articles/115001381931-Stopping-Bypass-Attempts
According to this official Circle site, you need visit www.brightcloud.com and check the categorization of the website or IP address, and submit a report if it's improperly categorized. Note that this tool is used by Circle.
