happyandbob
Oct 04, 2018Aspirant
Orbi blocking work VPN for some computers
Hi, I'm my Orbi appears to be blocking remote networks for some computers but not others.
When I connect to my work VPN via windows integrated VPN client, on older Windows 7 machines, the VPN c...
ekhalil
Dec 27, 2018Master
Please have a look here: https://support.meetcircle.com/hc/en-us/articles/115001381931-Stopping-Bypass-Attempts
According to this official Circle site, you need visit www.brightcloud.com and check the categorization of the website or IP address, and submit a report if it's improperly categorized. Note that this tool is used by Circle.
ericvdb
Dec 27, 2018Tutor
Thanks for the info.
I did put in a request, but i'm not sure how a category request will effect the circle settings. The app in question is Speedify, when i search on brightcloud then show up in the category 'Computer and Internet Security'. In the circle app, there is no category named anything like that.
Also, they ask for a url, i entered speedify.com, but would have no idea which urls their actual vpn service is using.
- ekhalilDec 27, 2018Master
Circle is using a dynamic database that is always changing based on such request that you’ve just made and from others. I hope that Circle developers will figure out which urls or services need to add to the database to take care of this shortcoming.
