jprice
Apr 02, 2021Aspirant
Orbi blocking Yamaha Musiccast app from connecting
I have an ORBI RBR50 router. I am trying to connect my Yamaha Musiccast app on my iPhone to the receiver. The ORBI is denying access. It thinks it is an attack. Here is the log from it (I think). ...
- Apr 03, 2021
jprice wrote:I have an ORBI RBR50 router. I am trying to connect my Yamaha Musiccast app on my iPhone to the receiver. The ORBI is denying access. It thinks it is an attack. Here is the log from it (I think).
I agree with the other reply that these logs are unrelated to your Yamaha app issue because they refer to outside access.
One thing to verify is make sure you've enabled Local Network access for the iPhone app: Go to iPhone Settings, pull down and search for "Yamaha", click on the Musiccast app, enable Local Network.
Mikey94025
Apr 03, 2021Hero
- jpriceApr 03, 2021Aspirant
That did the trick! Thank you!
