rjd185
Dec 16, 2020Aspirant
ORBI blocks iPhone updates which work fine on non-ORBI Wifi, same cable connection
RBR10 and 2xRBS10 setup (model numbers that no longer appear on the drop down list above although this package is less than one month installed). Summary of the issue here is that iPhones cannot upda...
rjd185
I hadn’t considered the double NAT (we have 192.168.2.x and 10.0.0.x) - good thought. I will see how I can remove that as a possible cause - we have one more iPhone still needing the update and I can switch off the BT WiFi. I’ll reply here again if it helps. Thanks.
Dec 16, 2020Guru - Experienced User
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
