Crick's avatar
Crick
Tutor
Jun 30, 2020
Orbi BRB50 assigns IP addresses in AP mode
Steps:
Factory reset BRB50
Log in over wi-fi
Set device to Access Point mode (DHCP connected)
Cable the BRB50 to a Nighthawk 7000 serving IP addresses in the 192.168.1.2-254 range
Reboot the BRB50.
The Orbi picks up an ip address in this rage: 192.168.107.xxx
It then assigns addresses in this range to devices that connect to it.
None of these connected devices can communicate with the Internet through the NIghthawk.
I can force connection of a device by fixing an IP address for the Nighthawk and setting the device to manually assigned IP address.
The Orbit did not used to do this. It used to connect as an AP quite compatibly.
Ideas?
    • antinode's avatar
      antinode
      Guru
      > [...] a Nighthawk 7000 [...]
         That's an R7000?  Look for "Model" on the product label.  Firmware
      version?  Connected to what?
         The first mystery would be from where it's getting that address.  If
      the R7000(?) is "serving IP addresses in the 192.168.1.2-254 range"
      (which would be normal), then my first guess would be that you have some
      other DHCP server on your network, and it's operating on a
      "192.168.107.*" subnet.  I would not bet that the DHCP server in an
      R7000 is granting IP addresses from some different, odd-ball subnet.
         If they're using different IP subnets, then that would not amaze me.
         I have no idea what that means.  "fixing" what, exactly, how,
      exactly?  "setting" how, exactly?  Describing actual operations with
      standard terminology would be more helpful than vague and idiosyncratic
      intepretations of what you think the meaning of what you did is.
      > The Orbit did not used to do this. [...]
         Perhaps you didn't always have some other DHCP server on your
      network.
      • Crick's avatar
        Crick
        Tutor
        Solved.
        The problem was that the ADT Alarm company's gateway, a Netgear device, was assigning IP addresses. The ADT installer, some years ago, connected the LAN side of the gateway to a switch serving my whole-house CAT5 network . This served a purpose at the time of allowing cameras or other ADT-controlled and wired devices to receive an PI address from the gateway. The Orbi, in access point mode, was on the same switch. This allowed the ADT gatway to assign IP addresses to wireless devices. The only mystery is why, over the past couple of years  the Orbi has been operating in this mode and configuration, was the ADT gateway not assigning addresses but instead the the Nighthawk R7000 managed to do all the wired and wireless IP assignments through the same switch.
        Regardless, mystery solved.
        Regardless, problem solved by disconnecting the LAN side of the ADT gateway from the physical network to which the Orbi attached.
        For reference and answer to antinode 's questions:
        • Yes, R7000.  There is no other Nighthawk with the 7000 number.
        • fixing, as in the verb, "fix": "to give a permanent or final form to." A fixed (static) IP address is an IP address is a dedicated IP address. In this context, "fixing" as in "assigning" - perhaps a dated term.
