wilro15
May 19, 2022Tutor
Orbi bricked after factory reset
I have an RBR50 plus two RBS50 satellites. I have a router provided by my ISP (its an Adtran model) which is cannot be put into Bridge mode. So this means I need to have the Orbi as an access point...
- May 19, 2022
I may have got it working...
I saw another post on here that said to tell the Orbi to use a fixed IP from your router when in access point mode, even though Netgear warns you not to. Also set the DNS servers to be public IPs, I used Google's 8.8.8.8 and 8.8.4.4.
Then power cycled the Orbi router and ISP router and it has started to work.
May 19, 2022Guru - Experienced User
Factory reset and access the RBRs web page at 192.168.1.1 using a wired PC or laptop and web browser.
If your ISP modem can't be bridged and it has a built in router, can configure the modems DMZ for use with the RBR and then leave the RBR in router mode.
- wilro15May 19, 2022Tutor
Thanks for your reply.
I have done a factory reset (fourth time today), connected via ethernet and setup the Orbi router as an access point. I have configured the wifi and can connect to the wifi from my phone and laptop. I chose for Orbi to get an IP dynamically from the router.
However I cannot connect to the internet, either over wifi to the Orbi or via ethernet to the Orbi.
The only thing that does work is that I can connect to the ISP router's admin page (which is the gateway & DHCP).
Oh, and the Orbi router has a solid magenta light
