wilro15's avatar
wilro15
Tutor
May 19, 2022
Orbi bricked after factory reset
I have an RBR50 plus two RBS50 satellites.  I have a router provided by my ISP (its an Adtran model) which is cannot be put into Bridge mode.  So this means I need to have the Orbi as an access point...
  • wilro15's avatar
    wilro15
    May 19, 2022
    I may have got it working...
    I saw another post on here that said to tell the Orbi to use a fixed IP from your router when in access point mode, even though Netgear warns you not to.  Also set the DNS servers to be public IPs, I used Google's 8.8.8.8 and 8.8.4.4.
    Then power cycled the Orbi router and ISP router and it has started to work.
