lambx
Apr 25, 2018Aspirant
Orbi Bridge Mode - No Connectivity
The model type does not include that I have two connected satellites.
When I enable bridge mode on my Xfinity gateway I lose all connectivity on my Orbi. I am having connectivity issues on a f...
lambx
Thank you for the response. There is an option to get DNS automatically from ISP, which is active. There is not a DHCP option under the orbi login.
Yes, I rebooted both, even reset Orbi and reintroduced the system.
Arris model TG1682G
Apr 25, 2018Guru - Experienced User
Possible that the bridge mode on the modem isn't working fully. I would ask the ISP or the mfr of this modem for help and information.
Set the modem back to router mode, then connect the Orbi router and reset it. Walk thru the set up wizard and allow it to set up the connection.
If this works, go into the modems web page and find the DMZ option, input the IP address the Orbi router gets from the modem into the modems DMZ. This will help with this double NAT condition.
