Hansen_acm
Jun 14, 2022Follower
Orbi bridge setup and chromecast issues
I have a couple of questions regarding my Orbi setup.
I have a modem connected to the internet cable from the internet provider. I then have my Orbi wired to the modem. Should I set up the modem in bridge mode, and what does it really do?
Secondly I have some issues with the chromecast in my living room. It keeps buffering. When I test my Wi-Fi speed in the living room it is almost at max speed? Anyone have any suggestions to fix it?
1 Reply
Hansen_acm wrote:
I have a modem connected to the internet cable from the internet provider. I then have my Orbi wired to the modem. Should I set up the modem in bridge mode, and what does it really do?Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.Sort that out and your chromecast issue may go way.
Hansen_acm wrote:
I have a couple of questions regarding my Orbi setup.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
