sangweb
Dec 03, 2020Aspirant
Orbi broadcast additional ssid calls netgear01
So I have RBR40 & RBS20. There is an additional ssid calls Netgear01, is this the backhaul network between the router & the satellite? I've tried to connect to it but unable to do so using the passwo...
CrimpOn
Dec 03, 2020Guru - Experienced User
sangweb wrote:So I have RBR40 & RBS20. There is an additional ssid calls Netgear01, is this the backhaul network between the router & the satellite? I've tried to connect to it but unable to do so using the password provided. TIA.
The 5G backhaul between satellite and router does not broadcast an SSID.
The SSID (that is not broadcast) can be found by opening this web page: http://orbilogin.net/hidden_info.htm
The credentials are the usual Orbi web credentials: "admin" and the password.
sangweb
Dec 10, 2020Aspirant
then why do I see this Netgear01 being broadcast as the strength is always the same as mine. Can't login the url you've provided but I can access the router on 192.168.1.1.
- sangwebDec 10, 2020Aspirant
NVM, I logged in & don't see this SSID on the list. It's still a mystery where this ssid comes from.
- FURRYe38Dec 10, 2020Guru - Experienced User
What happens if you turn OFF The RBR and RBS? Does this one SSID still appear?
Factory reset the RBS and RBR, press the reset button for 15 seconds then release. Setup the RBR with out the RBS. Use a wired PC and web browser connected at 192.168.1.1 or orblogin.com and walk thru the setup wizard. Set a new SSID name, and PW. Something unique and different than Netgear01. Does the Netgear01 appear afterwards?
sangweb wrote:then why do I see this Netgear01 being broadcast as the strength is always the same as mine. Can't login the url you've provided but I can access the router on 192.168.1.1.
- CrimpOnDec 10, 2020Guru - Experienced User
http:///192.168.1.1/hidden_info.htm should bring up a login box asking for the same credentials as 192.168.1.1 ("admin" and the Orbi web interface password).
