stevedpo
Nov 05, 2018Tutor
ORBI BRS WAN LAN Conflict - change to AP mode
I am just setting up my Orbi, along with a Netgear DM200 modem router. I get the BRS wan lan conflict when accessing most sites. I think I need to change the modem to modem only or the orbi to an acc...
stevedpo
Nov 06, 2018Tutor
thank you so much for your response. i actually found it is not possible to set a dmz on the netgear dm200 router. i did find i may have been dim in not recognising the prompt for an actual password when accessing the orbi settings via a browser, as opposed to the login i was getting for most sites. logged in i was able to set ap mode for the orbi and all working well now.
Nov 06, 2018Guru - Experienced User
Glad you got it working. Enjoy. :smileywink:
