matthewtshaver
Jul 07, 2018Aspirant
Orbi Cable Modem DHCP Issues
Hey everyone, we just installed an Orbi Cable Modem here in the past week. Allow me to share my setup with you all.
ISP: Comcast (no issue)
CableModem: Orbi CBR40 - Firmware: V2.1.4.6...
vkdelta
Jul 08, 2018NETGEAR Employee Retired
What are total Number of the Orbis you have in your setup?
CBR40 - Orbi Cable Router
RBS20 - Satellite that came in CBK40 Kit
Do you have another RBR50 connected in the setup in AP mode?
- matthewtshaverJul 31, 2018Aspirant
Still having the issues. It does not seem to be on the devices that are wired but often those that are wireless. We have the follwoing Orbi mesh system in a 4000 sq foot home.
Orbi Cable Modem: CBR40 (This device is in router mode)
Orbi Satellite: RBS20 connected wirelessly to the CBR40
Orbi Router: RBR50 (This device is in bridge mode) connected via ethernet to the CBR40
Orbi Satellite: RBS50 connected wirelessly to the RBR50
Per Netgear's support tech, I have binded the RBR50 (after putting it in bridge mode) to the the CBR40. I have additionally reserved the oast octet x.x.x.21 to my iPhone to test it. I'm still at my original issue:
Here's the issue: The CBR is routing traffic / supping DHCP address to about 30-35 devices within our home. When devices leave the network such as iPhones, or devices fall asleep such as Macs, when they attempt to get reconnect via WiFi, they have issues negotiating an address. Upon looking at the DHCP table, the devices are "active" and did not fall off the list. Inspecting the DHCP serving page, I do not see a lease time available? Is anyone else having issues. This does not happen to hard wired devices, only WiFi devices and they are not happening to just one iOS device it is all devices running iOS11.x, and I'm an app developer so I'm running iOS Dev 12.
- vkdeltaJul 31, 2018NETGEAR Employee Retired
Is your SSID for CBK40 and RBK50 system same?
Since they are two distinct system, they will not operate in same "mesh domain" (for the lack better terminology) and it might be creating problems.
CBR40 is the primary DHCP server in the network. Although it might be aware of L3 information from devices, it wont have information about L2/L1 (roaming, wifi, etc) and it will would treat them as wired devices coming off RBR50.
One suggestion is to:
Make a network with CBR40, RBS20 and RBS50 and sync them together (Remove any RBR50 off the network)
- matthewtshaverAug 04, 2018Aspirant
The house, as stated above, is 4000 sq. feet. When setting up the system, I was on the phone with Tech Support for quite a lengthy amount of time. I am not a network newbie, as I have a network certification from Cisco...so this is nothing too hard to achieve. After setting up the Orbi Cable Modem, I want to bind (via an Ethernet backhaul (really a backbone)) the RBR50 to allow a strong signal throughout the home. According to the tech, she had me hand type the name of the network into the RBR50, so it will only (by the way as advertised) announce one single SSID not two.
Today, I walk home with my iPhone...and the Orbi Cable Modem has to stutter when assigning an IP address though I have my iPhone reserved. I have the 2.4 channel at 11, 5 at 26. This all has to do with the Orbi Cable Modem and DHCP discovery - plain and simple. I walk into our home, my iPhone should auto join the one and only broadcasted SSID, yet it does not. When I go to iPhone settings, it sees the SSID but reports no Internet connectivity. I have to log into the CBR40, and check to see is this a Comcast cable issue, or a Netgear software issue. It's neither, and the logs are not explicit enough to know exactly what is happening.
I'm about ready to disable the routing feature of the CBR40 and make it a cable modem only (bridge mode), and allow the RBR50 to route and transmit the SSID. I cannot tell what is going on but previously the CBR40 was doing all my routing while the Comcast modem was providing Internet. This was supposed to be easy...it's not! Netgear sells Orbi as an expandable unit...and they really don't play well together. Thoughts?
