CLS2
Apr 26, 2021Aspirant
Orbi cable router CBR40
comcast has good signal to the Orbi. All my devices recognize the Orbi but no internet connection. Satellite is synced but no signal and no devices see it.
Apr 26, 2021Guru - Experienced User
Whats the status say on the CBRs web page under the Basic Tab?
Power OFF the CBR40 for 30 seconds then back ON. Turn OFF the RBS for now. Just test with the CBR40 only first.
- CLS2Apr 26, 2021Aspirant
tried turning off for extender periods several times in the 2+ hours spent with camcast tech, all w/o the satellite. The one test I perhaps should have performed was to connect a computer directly to the CBR40 and see if I had internet--that might have isolated the router component as the problem.
Not sure I understand your question re: the web page but I'll investigate; thanks.
