quagly
Apr 06, 2019Follower
orbi cable router or plain cable router to add to orbi system?
I will be purchasing a cable router. I have an Orbi RBR50 router and RBS 50 Satellite
I also plan to extend my network with an additional Satellite.
Can I using the CBR40 as a new base s...
SW_
Apr 06, 2019Prodigy
Just something to consider...
It's simpler to use a standalone modem, but one important drawback is that when Orbi fails for any reason, you will lose network access until you can fix or replace the Orbi HW. With the cable/router combo, you can quickly restore your network access and give you time to recover from Orbi failure. It's better to have a backup that you don't always need than to not have one when you need it most.
Apr 06, 2019Guru - Experienced User
I believe this was highlighted already. :smileywink:
