chicosan
Jan 30, 2021Initiate
Orbi: Can I roll back Firmware Upgrade?
Orbi Router RBR50, with 3 satellites RBS50 My Orbi mesh worked fine until I upgraded my firmware on January 8. My old Firmware version was V2.3.5.30, the new one is V2.5.2.4. Since the upgrade, t...
Jan 30, 2021Guru - Experienced User
There's actually 2 newer versions if you wanted to try updating before you try the downgrade.
but you can downgrade. its pretty easy. You just download the firmware for your devices from your support page and then follow the manual firmware update process. Make sure to change the satellites first.
chicosan
Thanks, I will try the newest version first.
I am slightly surprised, because the automatic update process says there is no newer version, but if there is, that's great!
