fede12345
May 07, 2020Follower
Orbi cannot change password
Hi, I initially setup my Orbi admin password and it contains an "ñ" character (non ASCII). Now I have downloaded the iOS App and the App does not allow for non ASCII characters in the password (S...
May 07, 2020Guru - Experienced User
You'll need to wire connect a PC to the router and factory reset the router using the back push pin button for 15 seconds then let go. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on. Be sure to not use any special characters for the admin PW.
