roarty58
Nov 06, 2021Guide
Orbi cannot verify server identity
This appears to be a recurring issue for many users. Has a solution been found? I get a message, "cannot verify server identity" and it references m.hotmail.com. The certificate is Netgear's ow...
roarty58
Nov 06, 2021Guide
Not sure why my images are not being displayed. They were screen shots of the error and the certificate.
CrimpOn
Nov 06, 2021Guru - Experienced User
Images placed "in-line" using the Photos icon in the menu bar do not appear to others until approved by a forum moderator. Images "attached" using the Browse button in the lower left are available immediately.
- plemansNov 06, 2021Guru - Experienced User
what modem/gateway are you connected to?
Are you using IPv6?
Have you tried a different DNS provider? If so, which one?
