roarty58
Nov 06, 2021Guide
Orbi cannot verify server identity
This appears to be a recurring issue for many users. Has a solution been found? I get a message, "cannot verify server identity" and it references m.hotmail.com. The certificate is Netgear's ow...
CrimpOn
Nov 06, 2021Guru - Experienced User
roarty58 wrote:
Not sure why my images are not being displayed. They were screen shots of the error and the certificate.
Images placed "in-line" using the Photos icon in the menu bar do not appear to others until approved by a forum moderator. Images "attached" using the Browse button in the lower left are available immediately.
what modem/gateway are you connected to?
Are you using IPv6?
Have you tried a different DNS provider? If so, which one?
- roarty58Nov 06, 2021Guide
Thank you for the reply.
- Running a Motorola MB8611 which is on my ISP approved list.
- Not using ipv6
- Have not tried another DNS, can do that next.
- plemansNov 07, 2021Guru - Experienced User
try enabling ipv6 and also try the different dns
- roarty58Nov 07, 2021Guide
Tried the Google DNS, issue went away for about 12 hours, then returned this morning. Trying OpenDNS next.
IPV6 - I don't know much about it, but will try it. I've read that is can cause some issues. Will try it and update on results tomorrow.
