roarty58
Nov 06, 2021Guide
Orbi cannot verify server identity
This appears to be a recurring issue for many users. Has a solution been found? I get a message, "cannot verify server identity" and it references m.hotmail.com. The certificate is Netgear's ow...
Nov 06, 2021Guru - Experienced User
what modem/gateway are you connected to?
Are you using IPv6?
Have you tried a different DNS provider? If so, which one?
roarty58
Nov 07, 2021Guide
Thank you for the reply.
- Running a Motorola MB8611 which is on my ISP approved list.
- Not using ipv6
- Have not tried another DNS, can do that next.
- plemansNov 07, 2021Guru - Experienced User
try enabling ipv6 and also try the different dns
- roarty58Nov 07, 2021Guide
Tried the Google DNS, issue went away for about 12 hours, then returned this morning. Trying OpenDNS next.
IPV6 - I don't know much about it, but will try it. I've read that is can cause some issues. Will try it and update on results tomorrow.
IPv6 is enabled and I continue getting the error and some of my devices continue to be unable to connect to the internet even though they are connected to the router.
Using OpenDNS servers.
