Nathanking90
Aug 31, 2019Tutor
Orbi can't connect to internet during setup
I just hooked up and activated the CM1000 and it seems to be working fine. Connecting directly to a PC gives internet, and connecting it to the old router (Google WiFi) also gives internet. However, I...
- Sep 02, 2019
I recieved my new system today and it installed just fine, not a single hiccup. It would seem that the previous router indeed had an issue with the yellow ethernet port or some other issue causing it to not connect to the internet.
Nathanking90
Aug 31, 2019Tutor
Everything is true up through accessing the web client, but I can't access tabs in the web client. When I use the IP the web client comes up fine, I can login just fine, but then it says I need to setup the router. I go through the steps to set it up then says there's no internet connection and setup can't continue.
Here's a screenshot of exactly what's going on. This happens in the client or the app.
michaelkenward
Sep 01, 2019Guru - Experienced User
Wow. I haven't see a photo as screen grab in some time. (Alt+PrintScreen with a PC is quicker and easier.) But that does suggest a trip back to basics.
As you have been trying to fix this with no luck, I'd be tempted to reset the Orbi to factory settings And then go carefully through the correct setup sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
As CrimpOn says, these things can be easier if you use a browser to get at graphical user interface (GUI).
- CrimpOnSep 01, 2019Guru - Experienced User
I went through a lot of paperclips getting my Orbi through a couple of firmware upgrade cycles. As michaelkenward says, sometimes even a new Orbi has a problem that can only be fixed by sticking something into the tiny "Reset" hole next to the power plug. Actually, since it has not been set up yet, there is "nothing to lose."
Hold the paperclip in until the power LED turns amber and then begins to flash amber.
- Nathanking90Sep 01, 2019TutorI was able to get a hold of a tech at Netgear, and after going back and forth for 30 minutes, factory resetting the router twice, verifying that I indeed have working internet, and manually entering settings during setup, we determined the yellow "internet" port is most likely busted. I bought the system on Amazon so I've went ahead and ordered a replacement.
I was on the forums on my phone, so it was easiest to just snap a pic on my phone real fast and upload it, lol.- Nathanking90Sep 02, 2019Tutor
