snowmantruckee
Feb 27, 2017Aspirant
ORBI can't log in and mac address is different
This just recently started: I have a ARRIS modem/router from my internet provider. IP address is 192.168.0.1. The wi-fi is disabled. In the list of connected devices on my ARRIS is my Orbi showing 1...
DarrenM
Mar 01, 2017Sr. NETGEAR Moderator
Hello snowmantruckee
Have you looked if there is any type of bridge settings or modem only in the ARRIS modem so it does not have a conflict with routing with the orbi.
DarrenM
- snowmantruckeeMar 01, 2017Aspirant
Darren,
The wi-fi setting for Arris has been turned off (for some time actually). To add to my confusion I can log into the Orbi from my cell phone with no problem, but not from my computer. (I used to be able to without difficulty)
- loomis1975Mar 01, 2017Luminary
Is your computer connecting wireless or wired? If Wired, is it wired into a port on the Orbi, or a port on the Arris?
It seems like your Arris gateway might still be acting like a router. It can still act like a router and have its wifi off. If you want the Arris device to be the router, then you should setup the Orbi in Access Point (AP) mode. You should be able to use any LAN ethernet port on the Arris to connect to the Orbi in this scenario.
If you want the Orbi to be the router, then you should see if you can put the Arris in modem only mode, or what might be called bridge mode, basically turning off the routing functions in the Arris. This might also dictate which specific LAN ethernet port you need to use to connect to the Orbi's WAN (yellow) port. The Arris's other LAN ethernet ports might become useless in this scenario. You might also be connecting to the Arris via a different IP address in this scenario than you are currently use to.
- snowmantruckeeMar 02, 2017Aspirant
Loomis (and all) Thank you so much for your advise. I was always hesitant to try using the Access Point. In any case I switched to Access Point. The ports on the back of Arriss modem/router still work, which was essential. I have one item, a signal booster hardwired to the cat5 on the back of the Orbi which may or may not be working. Have to determine if the 3 ports on the back of the Orbi still work or not. I can also log into the Orbi from my computer now.
It was a log week of electronic items in my house being taken over by the electron zombies.
