siuengr
May 01, 2020Tutor
Orbi can't login to CBS
I cannot login to CBS all access through the Orbi. I have tried https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125 Tried using a different DNS server, no luck ...
CrimpOn
May 01, 2020Guru - Experienced User
Would also help to know:
- Specifically what modem (brand & model) the Orbi is connected to, and
- If Orbi is in "router" (the default) or Access Point (AP) mode.
Thanks
- siuengrMay 01, 2020Tutor
CrimpOn wrote:Would also help to know:
Thanks
I use CHarter Spectrum. I don't know that modem it is.
The Orbi is in the default router mode.
- CrimpOnMay 01, 2020Guru - Experienced User
Thanks for the information. I also use Spectrum. would you happen to know the firmware release on the Orbi?
On the Orbi web interface, it is in the upper right corner.
Router Firmware Version
V2.3.5.30I just set this router up two days ago and started having this problem.
