siuengr
May 01, 2020Tutor
Orbi can't login to CBS
I cannot login to CBS all access through the Orbi. I have tried https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125 Tried using a different DNS server, no luck ...
CrimpOn
May 01, 2020Guru - Experienced User
Thanks for the information. I also use Spectrum. would you happen to know the firmware release on the Orbi?
On the Orbi web interface, it is in the upper right corner.
siuengr
May 01, 2020Tutor
Router Firmware Version
V2.3.5.30
I just set this router up two days ago and started having this problem.
