dfilip
Dec 25, 2021Guide
Orbi: Can't upgrade firmware on RBR40 / Can't load config from another RBR40
Have an existing RBR40 that is 3+ years old, and has started occasionally rebooting itself, so I purchased a replacement RBR40. This thread is NOT about why my old RBR40 is rebooting, it is about tr...
- Dec 25, 2021
Try installing 2.1.4.16 first, then try the 2.2.1.210
https://www.netgear.com/support/product/rbs40#download
Dec 25, 2021Guru - Experienced User
- dfilipJan 04, 2022Guide
Thanks, the problem is that I needed to install incremental firmware updates:
1. v1.11.0.20
2. v2.1.1.16
3. v2.0.0.56
4. v2.2.1.210
5. v2.3.1.48
6. v2.3.5.32
7. v2.6.1.36
8. v2.7.3.22Applying in the order worked for me.
