bha19
Jan 08, 2024Aspirant
orbi cbk 40? and 2.4 smart appliance
I thinh I have the Orbi cbk 40 and just bought a smart kitchen appliance that only works on 2.4 band. the problem is when I try to log in on the kitchen device it say incorrect password/refuse to con...
- Jan 10, 2024
Guest network seems to have worked although it said bad network it booted up.
Jan 08, 2024Guru - Experienced User
Try this. Turn OFF the RBS. Then the power output of the 5Ghz radio to 25%. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
