skyhawk214
Jan 16, 2021Aspirant
Orbi CBK40 having lots of problems with satellites
My landlord installed an Orbi mesh system for the house I live in, and it's been nothing but confusing problems ever since. I'm helping to fix it, but I do not know the credentials to get to the logi...
Jan 16, 2021Guru - Experienced User
Things we'll need feedback on:
What Firmware version is currently loaded? What on CBR and RBS.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- skyhawk214Jan 16, 2021Aspirant
All the device's firmware is up to date. This isn't a speed issue. This is a latency and connectivity issue,
