misterblvck
May 23, 2020Follower
Orbi CBK40 Issues
I have had this Orbi modem/router for almost 3 months now. Within the first week of buying this product, we experienced this same issue. Went through Netgear Technical Support and was stuck on the ph...
May 25, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
