rxrush
Dec 04, 2023Tutor
Orbi cbk40 issues
I cannot access orbilogin.com or connect to router on orbi app or 192.168.1.1 The modem and the connected satellites are working fine. Is there anything I can do besides a factory reset. Any help wou...
- Dec 06, 2023I was able to fix it by completely turning everything from the modem (cbr40) and satellite(rbs20) off for 10 minutes and then restarting just the modem. I was able to enter the modem/router settings of the cbr40. All is well.
michaelkenward
Dec 05, 2023Guru - Experienced User
What happens when you try? Any error messages?
What is that modem?
- rxrushDec 06, 2023TutorI was able to fix it by completely turning everything from the modem (cbr40) and satellite(rbs20) off for 10 minutes and then restarting just the modem. I was able to enter the modem/router settings of the cbr40. All is well.
- FURRYe38Dec 06, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
