blayz1
Jul 03, 2019Aspirant
Orbi CBK40 username password reset help needed from Netgear mod
Unit will not reset to factory settings via reset button. Attempted firmware update via TFTP but it would not load. Previous owner passed away so could not access/change network username and password...
- Jul 08, 2019
What happens if you disconnect the coax from the back of the CBR40, then press the reset button in back for 15 seconds, leaving your wired PC connected to the CBR40. You don't need internet access to access the setup wizard. Your PC should get a 192.168.1.something address and then you should be able to access the CBR40s web page at 192.168.1.1...
blayz1
Jul 08, 2019Aspirant
Nope did not activate Armor or anything else just followed the setup wizard and updated FW. Not sure which version was previously installed just that it was shut down in late 2018 and not updated since then. Do you think I should contact my ISP tech support about the FW issue?
blayz1
btw...speed test results within router settings a bit better but still nowhere near 400 mbps..
Download - 214.89 mbps
Upload - 23.31 mbps
