tmbrw4545
Dec 09, 2020Follower
Orbi CBR 40
I set up my new Orbi CBR 40 moden router from my xfinity supplied unit and I am having more issues and wifi outages than with the xfinity unit!! why? I have one satellite as well.
Dec 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
