pxlla
Feb 24, 2020Tutor
Orbi CBR40 - How can I dim the VERY bright lights?
I've just installed my new Orbi and performed all the updates and firmware. I saw one ppost on the forum about a year and a half ago that referenced this issue. Is this something that can be added to the developer feature list. The lights on this modem are so bright they actually light up the room!
(Caveat: I do not have this model, but...) The only "light" that is supposed to be on during normal operation is the tiny Power LED which is on the back and will be green. https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Which light light remains on (and bright)?
Be sure to post about this in the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Good Luck.
pxlla wrote:I've just installed my new Orbi and performed all the updates and firmware. I saw one ppost on the forum about a year and a half ago that referenced this issue. Is this something that can be added to the developer feature list. The lights on this modem are so bright they actually light up the room!
Any progress on this?
